I installed new front fogs on my car but I can't get them to turn on do I need to change the steering wheel control arm
Yes, you just need the turn signal switch with a fog light switch on it.
You can get one from an older Maxima around 05 or so.
I pulled mine off of a Pathfinder/ Infinity equivalent, so I had the rear wiper switch to match.
You may have to do some fitting, but you can use almost any Nissan/Infinity turn signal switch up to about 2009. You can use the Tiida up to 2011, or 2012 hatch.
The fitting is that there are 2 different type of plugs the switches use. one type will not fit.
I do have a thread I made last summer that has fairly complete info.
Yes, after installing fog lights to pig tails you will need to upgrade your column switch to one with the fog light option. I would get one used off of eBay from an Altima or maxima i believe its the same column switch for your vehicle but look at yours to be sure, they should be plug and play.
Cheers
