My front power window motor went out on my 2008 Versa hatchback. I could sometimes get it to work by tapping on the motor.
I replaced the motor with an aftermarket part. It worked fine for about a week then just died again.
I don't know if the new motor when bad or what. I can't get it to do anything. I have tried tapping on the motor, unplugging it from the switch and the harness, moving the switch in all positions (over and over) and nothing. It's just dead. All the other windows still work fine. That leads me to believe the switch did not go bad and maybe the new motor did.
Is there a way to test the motor before I order another one?
It leads me to believe that the switch is what is bad. I have seen bad switches do as you describe in a number of different vehicles.
