Does anyone know if the fuel injectors from the mr16det will fit into the hr16de I need larger injectors to compensate for the increased air flow but nobody makes them that I've seen and I'm not sure what other engines have compatible injectors that are higher cc.
Rockauto will show you all the vehicles a part works for but you need to start by make model and year.
Size is kind of a crap shoot. To add more fuel you could always increase psi, use an extra injector, methanol injection, etc.
Increased airflow? Unless you have forced induction or serious motor upgrades you won't see a benefit with bigger injectors.
+1. Ive got lean codes running e85 in other vehicles in colder weather. No problems here, so they must flow more than Honda injectors.
Not sure what Versa you have but is it rated for E85? If not, that ethanol is going to corrode your fuel lines and eat anything else that isn't rated for E85. Additionally, the offset between the lower cost and substantial increase in fuel consumption for E85 usually is a net loss in terms of fuel cost for mileage.
Even if my vehicle were rated for E85, I would ever put that junk in there.
3 Participants
Cobb
