Lately I've been noticing some odd fluctuations in the fuel gauge over the past week or so. The needle drops to the bottom when the car is off just like normal. When I turn it on, it jumps to the level where it should be, then over the next few minutes or it drifts downward or upward by as much as 1/8th of a tank. It's never really, really off. It's like the sensor can't make up its mind about exactly how much fuel is really in the tank.
I've also been having an issue with sluggish acceleration when stepping on the gas. If I accelerate normally, everything is fine. If I apply the gas enough so the car would jump forward, it goes into "creep forward mode" for about 15 seconds or so or until I shift into neutral and back. The engine RPMs increase, but the speed stays at around 5 MPH. I read this might be due to the brake light sensor, but the brake lights are working normally.
The "service engine soon" light came on yesterday. I immediately checked the gas cap, and while the seal didn't look damaged, I didn't notice the sucking sound I usually get when opening the tank.
The odd thing is, other than these two issues, the car runs fine. Starts right up on the first crank. Accelerates normally from a slow start or while in motion.
The weather has just started to get cold here. I was thinking the temperature may have caused the rubber seal on the cap to fail. I have not had the OBD error code read yet, but I was wondering if this might be the cause?
