Hope this helps. (See link)Has anyone done a fuel pressure test on a Versa. If so, please explain how. Thank you!
I posted a reply to your forum post that is awaiting admin/moderator approval for some reason.Has anyone done a fuel pressure test on a Versa. If so, please explain how. Thank you!
Hey Versa_gtir, I'm truly thankful that the moderator released the hold on this message. I didn't get a notification but I circled back around and your message helped prompt me to return to the Factory Service Manual. Section EC-574 Fuel Pressure Test is very helpful. The only problem is, I can't find the part, the Fuel Tube Adapter (KV10118400) that the manual refers to Anywhere. There is only one site that popped-up in Google for that specific part, and it's in the UK. If anyone knows of a store, site or link in the states to find this adapter, please respond. I know there are multiple generic fuel line/fuel tube adapters available from sites like Rockauto, but I don't want to gamble on the size. I already bought the generic fuel pressure test kit from harbor freight, but there is no adapter to tie into the quick connect (female side) once I get it released. I can hose clamp the male side, but need an adapter (that fits) for the female side. I've seen multiple references to the Fuel Tube Adapter in multiple FSMs under both part number KV10118400 & KV10120000, but can't find them anywhere other that some generic UK site (No offense to the UK, but I don't want to pay $30 plus $30 shipping for essentially a piece of fuel pipe with a barb on it, but I do want the right size). As always, thanks to the community, and thanks to Versa_gtir. For reference, mine is a MR18DE SL.Hope this helps. (See link)
If you are referring to the 1.6L HR16DE, the process is slightly different. You can download the FSM from NICOclub or Cardiagn.com for your Versa to find the exact procedure.
The HR16DE is used in all three generations currently, but was slightly altered after each redesign (the 1.8L MR18DE was offered alongside the 1.6L in the 1st gen models as an option on S and SL trims).
Fuel pressure test
Any one ever test there fuel pressure? I'm wanting to do mine to diagnose a problem. I'm wondering if anyone could Point me in the direction of a place to tap into the fuel system to test and possible pressure reading that are correct?????www.nissanversaforums.com
