Can anyone please tell me what the fuel pump pressure ( PSI ) is from the new fuel pump to the injectors on my 2007 Versa 1.8L and does anyone have a good place to buy a Fuse box brain with relays.the one mounted under the hood on the drivers side finder? Thank you all for your time and hopefully your response.
Around 50 psi at idle.
That brain is called the IPDM, may help you find it faster. Integrated power distribution module.
Thank you for your reply .but it will not start to get a reading on the pump at idle.should be about the same I guess
