Are there any specific symptoms for a fuel pump/regulator etc. going bad? Some of you might remember a problem I had a couple months back when my car wouldn't start. Well it ended up not been the Pump cause the car started like two days later and hadn't had any issues, till now. Just over the weekend I tried starting the car in fairly warmed weather but had a hard time. I was able to started but only after several attempts. I'm not too mechanically oriented or know many terms but all I can say is that I tried turning the key and the car would, correct me if i'm wrong, crank but wouldn't start. Only after 3-4 attempts and pressing the gas petal on the last attempt did it start. This was yesterday morning and it hasn't happened again, yet. So I guess my question is are there any tells to when something is wrong and should be replaced or looked into? Thanks much
