I heard mine!
Okay, the fuel pump does kick in for one (second like every other car...)
Turn the radio off, and roll the windows up. This pump is very very quiet in my opinion
The fuel pump sound comes from under the rear seat so you have to put your head down by the rear seat and you will be able to hear it for about one second mmmmmmmmmmmmmmmhhh it is a very quiet fuel pump
If you’re able to hear the pump kick in, and the crank turns but it doesn’t start, let us know
If you do not hear the fuel pump kick in, then your injectors are not getting any fuel to spray
Check the fuse box. Not sure if the fuel pump has a relay switch? Because maybe the relay is bad and not the pump if it has a relay and its damaged.
this reminds me, I need to change my fuel filter
