Hi all! I’m trying to see if the fuel temp sensor is working or if there is troubling in the wire connecting to it. I have removed backseat and accessed fuel pump lid. I disconnected the 5-way fuel pump harness connector. I’m not sure which pins to test for the fuel sensor. If anyone can suggest the next steps or have a wiring diagram, it would be much appreciated. Thanks!
Tough to test this one without a scantool that can see the tank temp sensor. The sensor is submerged, so testing at it is another issue. The connector test will only give you so much info. Common failure and the fix is a new pump, unless you can source the sensor somewhere.
