hello every one, I need a help to figure out which fuse is for the OBD port, I believe the OBD port is not working because of the fuse,
Here is the pin out for the OBDII portUse a test light and see if the obd port is getting power. If it is, then its not a fuse
can I use voltmeter?Here is the pin out for the OBDII port
