Hello, I Just Purchased Nissan Versa 1.8 sl hatchback.
Gas Gauge Doesn't Seem To Be Working. Anyone Else With That Issue? Is This A Common Problem With 2009 Nissan Versa 1.8 sl hatchbacks? Is This An Electrical Problem, In Which Forum Should I Post This Question?
Also, In Other Cars When You Unscrew The Gas Cap, There Is Usually A Metal Piece In The Tube Going Into The Gas Tank. Usually It Is Visible Where You Insert The Gas Pump Nozzle. Is There Supposed To Be a Metal Piece In The Nissan Versa Gas Fillup Area?
I Hear A High Pitch Sound That Could Be a Belt Going Bad. Someone Told Me The Versa Has A Timing Chain, Not A Belt, So What Might Cause A Screechy High Pitch Sound Like A Belt Going Bad? It Happens Occassionally When I Drive, Not Very Often, But Noticeable.
The Manual Indicates There Are Master Keys. Since We Are Buying This Car Third Hand, We Were Handed Two Fobs Which Have Mechanical Keys In The Fobs. Is It Worthwhile To Obtain Master Keys FromThe Dealership? Has AnyonE On This Forum Done That? I Was GoingTo Ask The Seller If They Might Have The Master Keys.
How Is Your Mileage Over All?
Do You Notice The Engine Seems Happiest At 50 Mph or lower? The Car Can Go At Higher Speeds, Just Seems Happier At 50 Or Lower.
What Type Of Coolant Do You Use?
Thank You For YouR Help.
