#8 · a moment ago
I have a 2012 Nissan Versa Hatchback 1.8L S trim automatic. I'm suddenly having an issue with fuel mileage. I can usually get close to 500 miles to a full tank of fuel. A month ago I took a trip and went 464 miles on one tank. As of a week ago that has suddenly dropped by about half. I have had to refuel 4x in 3 days. Total miles on each tank were: 164, 179, 243 and 274. I thought it might be bad fuel and I had refueled with regular vs the midgrade I usually use. So I put a fuel system cleaner and an Octane booster in the tank before refueling, which brought the total miles per tank into the 200 range vs the 100. Still not good. I also noticed this morning that I wasn't in Overdrive and was on the freeway doing 70mph. However, when I press the Overdrive button, my OD light on the dash does not come on nor do I feel much difference when I press the OD button on the shifter. Not sure if that could be contributing to my fuel issue or not.
Any thoughts would be greatly appreciated. Thanks.
Will try to address a few things:
O/D Light- The light will only come on when O/D is turned OFF via switch.
Fuel- It had been cold and snowy across a lot of the U.S. this past week. Running the defroster WILL cut down on fuel economy, as will warming up the car.
A few questions-
How many miles on the car?
Is there any Check Engine Light?
When was the last service on the car(oil, trans)?
Are tires to proper inflation?
