1 - 20 of 32 Posts
I wanted to put XM in my car without using an external receiver, so I did some research and found the Bosch Nav unit was the best option.
These were found in the following:
Versa
Sentra
Cube
Juke
NV
These were commonly used between 2010 and 2012.
All will work in the Gen 1 Versa with 1 or 2 little mods on the main 20 pin connector.
1- Most will have to add a ground wire to pin 20 and to a body ground. The original radios get their ground through the radio chassis itself, unlike the Nav radios.
Hence this mod.
2- Those originally with base radios will have to add a VSS wire to pin 18 and to pin 4 on the cluster connector.
Those originally with speed sensitive volume do not need to do this mod.
Everything else is the same on the 20 pin connector.
I am just sharing the basics so far. I am waiting on a few parts before I do the install.
BTW I got my radio out of a 2012 Cube.
Discussion Starter #2 (Edited)
Just finished installing the Sat/Nav and all I can say is WOW!
This thing sounds as good as, or better, than the Bose system in my Saab.
I have the premium speakers(Clarion tweeters/Blaupunkt speakers) and those tweeters really come to life. Had to turn bass down and still has a solid low/mid.
So I can confirm that Juke and Cube Bosch Sat/Nav radios up to 2013 WILL work in the Gen. 1 Versa.
I had to run wire from the gauge cluster pin 4 to pin 18 on the radio. also added a ground wire from pin 20 to a body ground.
I also had to cut down the GPS antenna mount so it would fit in the Versa location
Those were the only mods I needed to make.
So here is the mishmash of parts I used for the install:
Radio from 2012 Cube
AM/FM/XM antenna and most antenna wire from 2015 Note.
XM antenna wire from A pillar to radio from 2013 Juke
AM/FM antenna wire from A pillar to radio is what came with car.
GPS antenna from 2013 Sentra.
Still waiting on 2012 radio bezel with USB/Aux port and cable(should be in next week).
When all is said and done, everything was about $200 and about 4 hours of labor to install it.
Worth it? HELL YA!!!
Radio with radio on. This is the bezel needed for this radio. Any Versa with either Nav or an Ipod dock will look like this. Ipod dock and USB/Aux can be easily swapped out.
17630
Nav screen
17631
Post some pics when you get a chance. My son has been itching to dump his 2011 Versa HB that is still running well (except for the AC) with 125k miles. Rather than spend $10k+ on something new I suggested he upgrade wheels (all his wheel covers have been broken by Discount Tire), get the windows slightly tinted and a new stereo unit. I like what you just did. May be worth an upgrade.
Sent from my SM-N960U1 using Tapatalk
Discussion Starter #4
I will take some when the Sun comes out this morning.
Here is a list of what I have done to mine:
SL seats, door panels, center console, leather wheel
Aluminum wheels
Sat/Nav radio
Fog lights
Auto dimming mirror w/compass and Homelink
Premium speakers/tweeters and A pillar trim
I see you are not too far from me, I am in the West burbs. I can help in where to go for stuff.
My favorite yards are in Aurora and Blue Island.
  • Like
Reactions: V65
Here are some pics of what I have done to my car as requested by V65
They show most of what I have done.....so far!
Interior from 08 SL. All but the fold down rear seatback came from a sedan.
AM/FM/XM/Nav radio
Auto dimming mirror with compass and Homelink
Leather SL wheel
15" SL wheels
  • Like
Reactions: Bumble_Bee and V65
Discussion Starter #6 (Edited)
A few more and one of the Saab and Harleys for fun!
AM/FM/XM antenna from 15 Note
Fog lights from 12 Cube. Same Cube the radio came out of.
Harley Ultra Classic, Harley Sportster 1200, and Saab 9-7x
All that is missing is the Yamaha XS 750.
  • Like
Discussion Starter #8
Wired it into the fuse block by the left knee. ran wires across to the right pillar, and added to the plug/harness that powers the dome light.
thanks!
so basically it's just three wires: one to the fuse box, one to the dome lamp harness, one is ground. I do have a couple of questions:
1) did you buy an OEM mirror or an aftermarket one?
2) did you tap into the power dome light wire or did you use another blank cavity?
thanks
ps: I also sent you a private message because I'd like to ask you something that is not thread related :)
Discussion Starter #10
OEM mirror from an Altima. Auto dimming mirror with compass and homelink.
I'm currently not using Homelink so I haven't put the fuse in to power it.
1 wire from fusebox for key on power
1 wire from fusebox for constant on power
1 wire from ground under passenger airbag
I ran wires from unused circuts in that fusebox and made them individual 10A circuts
there were open pins on the connectors for the dome light harness and just added the wires to that.
Discussion Starter #13
yes
Discussion Starter #14
Since I've posted pics of the other stuff I did, I will add the most recent change.
Went from a leather SL wheel to one from an 08 Altima.
08 SL leather wheel. Note original cluster.
17628
08 Altima Wheel. Note the cluster from a 11 hatch (did have it sent out to set milage for my car)
17629
  • Like
Reactions: Ecate
Discussion Starter #16
Sitting on a shelf in my garage. Prefer the white back lighting compared to the pee yellow of the original.
Discussion Starter #18
The yellowish along with the red needles aren't exactly the best color combo. Easier to see red needles on the white background.
I have the same white/red needles color combo in my work truck. Doesn't reflect off the windows and is easy to read at a glance.
Oh, I think it's two wires...connected to the D2 and D101 harnesses...seems easy, I'll try tomorrow :)
1 - 20 of 32 Posts
