Our (plastic) intake manifolds have a bit of a grid on the inside just after the throttle body, in the plenum before the intake runners. Anyone have any idea if it's a restriction? My oppinion is that it's either just there as a result of the moulding process, or for structural support under high vacuum. Oppinions? It HAS to be a restriction at high RPM. But these motors were designed for low end torque, every design feature about them indicates this.
When experimenting with cold air intake designs (ABS pipe, easy and cheap to play around with), when using a large diameter (3" ID) pipe, i lost pretty much all low end grunt. To the point where airflow seems to stall until about 2500RPM, it's less pronounced in the lower gears obviously, but if you're in 5th lets say, and you mash it, it will bog a little before the revs climb. Top end power and response improved greatly. My oppinion is that the stock intake system is good, it already gets ambient air from the gap between the hood and core support. It also has resonance chambers to pack in air at low RPM.
It would be nice to see how Dynatek made high RPM gains but kept all the stock low end. From pictures it looks like their intake has a larger plenum/chamber/tank feeding the runners.
