I have a 2012 Versa HB that just had it's tune up. I'm on 116,000 miles. Now, the car recently did the short vibrations while stopped and I was told that's normal but I figured let me just go in for the tune up and the oil change. After my tune up, my car would make a grinding noise while braking and when stopped on Drive inconsistently and for short periods of time. Over the next couple of days, the grinding while braking went away and now the noise only happens when I'm at a complete stop while on Drive. I've been putting my car on Park while stopped at a light. The dealership has agreed to look into it since it happened after the service but I am curious to cross check information from people here. I can't describe the grinding noise very well but it doesn't sound likes it's metal hitting metal.
Read up on the other posts about CVT problems.
You may have a bit of a decision to make as you are well past the warranty.
Check the heat shields under the car and the engine and trans mounts, just could be an issue with one of those.
Thanks for sharing your experience with your vehicle whenever the vehicle creates an issue like a flat tire and complete stop while on Drive I will suggest you use Roadside Assistance Services platform most trusted and reliable service provider I also use this platform that way I suggest you
