H&R lowering springs for 2012-2014 sedan
4651 Views 7 Replies 6 Participants Last post by  Cobb
I looked on the H&R web site and looked for springs for the 2012-2014 versa sedan it said they have springs for the 2013. Will that work or did they make a versa hatchback in 2013?
1 - 8 of 8 Posts
why is it that it seems no body here in this forum has not lowered there 2012+ sedan...
except for Psm1 which just states that he used megan racing springs...
no part number or nut'n...
anybody else bought springs for their 2012+ sedan...??
with a part number please
Same here!! i can't find any springs for 2012+ sedan
same here! i can't find any lowering springs for 2012+ sedan
Its such a nice riding vehicle its not needed. Hell, I actually added a 1 inch spacer to the rear springs to make it sit slight taller in the back.
Ill likely get the megan kit with adjustable springs and shocks if I want something better. Ill also go to an alloy wheel, but both a bigger and taller tire.
Oh no I want to slam my versa 2014 sedan. Will I really have to cut springs. Isn't that super unsafe and makes u have to buy parts like a little while?????
If you had coilovers you can adjust them at the gas station before a show to slam it, then raise it back up when its over.
Ive had tanabe nf, df, H&R, and they all sag over time if you use it as a DD and carry a few subs, large sub, 2nd battery, 2-3 amps. :grin
Why not use the Megan Racing? years ago when the 2012s were coming out Megan Racing took a member Versa on here to use and design the springs and an exhaust.
Most spring manufacturers will make you a one off set for around 600 bucks. Just tell them the specs, weight, etc. THis way you can include weight of a sub setup, rear engine or some other modification that effects weight like putting a v6 or v8 under the hood. I use to know a place in MD that made coil springs to order. If you got like 14 orders they were like 200 a set.
1 - 8 of 8 Posts
