I have a 2009 Versa SL, and one of my head lights is having a problem. Its weird cause the DTRL works fine and the highbeams work but the low beams do not work on only the one head light. I have already tried to change the headlight bulb and that did not fix the problem.
I have looked for fuses that could be related and i looked in both boxes (the one under the drivers side dash) and the one in under the hood on the drivers side. None of them say they are related to the headlights unless i missed something? I did see one called DTRL and there is only one there and it is NOT blown.
Also i did find a small box on passenger side under the hood that contains two relays. a black one with 6pins and a blue one with 4 pins.. would these be the headlight relays?
Also does anyone have any other suggestions on what to look for or test for this?
Thanks
Thanks
