i have a 2011 Nissan versa hatchback 1.8l and I'm putting front brakes on rotors and pads which i have done in the past and never had an issue but this time im replacing the caliper slide pins. The issue is i pulled the caliper brackets off both sides so i could clean them and install the new slide pins and as i went to install them i realized the pins are not the same one has a rubber type sleeve on it and the other pin doesn't and I'm not sure which pin goes on the top or on the bottom since i have both sides apart . I've looked online and tried watching some you tube videos of guys doing versa front brakes and cant seem to find one that shows anything . If anyone can help me out of i would really appreciate it . thanks .
