hey for a 2009 anyone know if the bolts are 114.3mm or 100mm? Also will stock alloys from a SL be a direct replacement for car S that came with steels ?
Thanks
It's the 114.3 pattern as for the wheels I'm sure they should fit. I tried some stock wheels from a sentra sr on my versa and they fit.
Sent from my SM-G960U using Tapatalk
Yes, the SL wheels are a direct bolt on. Did it on my 09.
You will need new lug nuts though.
Why and what size ?
Don't know the size, but if you presently have steel rims, the lugs for the steel rims will usually be too short to mount the alloy rims correctly. Same goes in the other direction. When I had my Mercedes with alloy wheels, the spare was mounted on a steel rim that came with its own set of shorter lugs. If you tried to mount the steel rim with the longer alloy lugs, the lugs would go in too deep and stop the wheel from turning.
