First thing to check is tire pressure. Make sure your tires are not over inflated. Based on the mileage of the car, you might look at the shocks. If they are worn, you will get uneven tire wear, along with the rough ride you describe. Good luck!!Hello. I have a 07 versa. I feel every bump in my car, every crack, everything. What can I do? New shocks? Suggestions.
