Letting you guys/gals know if you ever happen to open your hood on the car to be careful. I pulled the lever too fast, and the metal wire came loose from the lever. Its not attached anymore so I have to pull on the wire to open the hood. I knew it was bound to happen soon enough.
I'm going to take it into the dealer Tuesday morning at 10:30 and get it repaired, nothing is broken it just needs to be reattached to the plastic mounts so its stationary for the hood lever to do the job. Hopefully its covered under warranty. If you want, I can take pictures for a visual aid.
