On my 07 Versa my horn stopped working. When I check continuity on my clock spring it is there. When I check continuity on the single wire that connects to the clock spring it is there. However, when that wire is connected there is no continuity. What would be the problem?
Check the horn relay under the hood(I forget the number), if it clicks when you press the horn button it is good.
Most likely, it is the connectors at the horn itself that are bad. They tend to corrode after time. I had to cut back about 1/2 inch on my 09 to get to clean wire and solder some new connectors on.
I have already replaced the relay and fuse along with installed brand new horns. When I hit the lock button on the fob the horns sound so I know those aren’t the causes.
Horns are over rated. Best to hit the brakes and steer if someones in the way or you are in someones way. >:D
