I wanted to know if anyone knows a good step by step guide on installing a backup camera to a 2007 Nissan Versa SL Hatchback?
Theres more than one way to do it. Now you can get wireless cameras that use your phone, require you to replace your rear view mirror or use a smaller monitor on your dash or through the screen of an upgraded radio with tv like screen.
Me, I got the plate camera to go around my license plate and made a small hole by one of the license plate plastic screw inserts to run the wire. I then taped it to the driver side hatch bracket to the top of the interior of the trunk to under the back seat down the center towards the driver side to up under the dash. I then need to mount it to a switch with 12 volts + and to the lead and camera input of my car play radio.
To get it to work I grounded it in the trunk and will use it by a switch so I can use it to merge in tight situations, rather or not I am in reverse. Otherwise you tap the reverse lamp lead for power when you are in reverse to power the camera and to trip the sensor lead on the radio.
