561 - 580 of 607 Posts
I have a 2012 Versa and I just hit 110K. Still running great, knock on wood. Her name is Vera; Vera the Versa.
I'm starting to feel like we baby our versa too much lol. 2012 and Only has 48k on it...no one likes a show off but we just paid it off last week...a year early!
Sent from my LG-H900 using Tapatalk
+1 Its a fun little car for a 4 banger and 100 hp/tq. Then again a "square" engine is like that.
As long as I am game you cant pass me til I hit 5 past the speed limit. >:D
I must REALLY baby mine. 09 S and only 86K.
Then again, I'm trying to get every last mile out of my 02 STS...at 180k!
Nice! We are they same way. We drive our 08 toyota highlander way more. It has 123k.
2016 Note SV w/CVT
Just turned 40,000 today
Still has the factory tires that came on it.
Like many....knocking on wood: Have just changed the oil and put gas in it.
100K miles. '11 S MR18 4sp ATX.
The engine needs plugs, it misses at idle occasionally then straightens back up with a few cuss words. The trunk and license plate lamps failed and traced to a crap retention method in both and fixed by me not to do it anymore. I upgraded the interior light but only to the max amp size the bulb type would accept, any more and I may fail the auto-off chip from too much amp to it. That timer controls a lot of other things so I don't want to be buying a new BCM based on that 50 cent chip. Contemplating another much brighter standalone method, the interior light even modded is abysmal. The pass side engine mount has a toggle weight molded into it that offsets vibration by opposite moment, the weight is about to fall out of the rubber and it affects the 'dongle' which is how it works and now it shows up as vibration at idle in gear like the Focus cars I have. I simply cannot grasp why the OEMs have gone to the single pass side centered mount so many of them use now, they so greatly affect engine vibration at idle when the mounts get old. Older cars that mounted underneath rather than over the engine NEVER vibrated as bad as this method does. On the Focus cars the vibration can shake your face off. I hope this one doesn't do that. The tire pressure sensors are now dying from dead batteries, gonna have to work that issue out and trying to figure out how to without spending $$$$$$. The outrigger cover plastic trim at lower door sill on driver side keeps coming off, I'll have to screw that positively down. I had to reattach an a/c hose mount that loosened up to let the soft metal hose erode to possible fail, that is tight now. I learned as well how to carefully clean an air filter on these to then have it go back on car like a new one. Working out how to install a water temperature gauge, I would have given up the tach for one for sure. Does anybody hate the severe glare that comes from reflection of the silver driver side HVAC duct cover plate to show right in your driver side mirror? I swear I have resisted yanking that plate to paint it flat black like a hundred times now. I removed the rear seat headrests to greatly increase the rear view through the center mirror, nobody ever uses the back seat. I'm using an engine oil filter that is easily 3X the size of the OEM puny thing. I yanked and tossed the engine bottom cover and the top engine beauty cover to make maintenance easier and to find leaks faster. I modded the fresh air intake snorkel to drop the boost bottle on the side of the battery. I switched the ATX to Ford ATF to better find price deals and it runs fine. I don't care for bare wheels but I yanked wheel covers as I don't care even more for dying on a freeway due to extra time spent as a target trying to remove a stupid wheel cover. I always carry a quickjack as well, no screw forever OEM jacks to shorten time changing tires, you'll have a flat at midnight or again on freeway and again you are a target.
A lotta stuff in there, huh? I never leave any of my cars alone, I am driven to mod whatever I need to get them the way I want.
2016 Versa Note - Picked it up used last year from Hertz Rentals at abiout 49,000 miles. Have 74,000 miles on it now.
About 5K ago, it started making a metallic squeaking/clicking noise when I accelerate lightly. I think it might be coming from the transmission. fuel economy last year at 95 Deg F was around 32mpg. this year it seems to have dropped to about 26 mpg.
Temps in the 80s now, and averaging about 32 mpg.
Have you changed the CVT fluid at all?
Reason I say that is we bought our 2016 Nissan Quest minivan used as an ex-rental (came from Hertz, but bought it "certified used" from a Nissan store). I bought it in 2017 with 32K miles on it. The factory CVT fluid was almost as black as used engine oil. I do 3.5qt drain/fills on it a few times a year with Nissan NS-3 fluid I buy off eBay for $10/qt shipped. It's $20/qt at my local Nissan parts counter. If my CVT fails, it ain't gonna be due to fluid maintenance!
100K miles. '11 S MR18 4sp ATX..
Man you're not kidding about the dome light! With an all black interior, you can barely tell the thing is on in our 2015 Versa 1.6s model. I have noticed that the selector switch on the dome lamp is fiddly as well with weak contacts.
The 1.6s sedan models are seem to be way more de-contented than the ~2007-2012 1.8 hatchbacks. No under cladding at all, which I guess isn't a bad thing, but the engine bay was FILTHY with road grime on mine when I bought it. One of the first things I did was give the engine bay a gentle soap down and spray clean after I hand washed the car. No sound deadening engine cover either so you really hear lots of engine noise and intake noise like it's got a $10 eBay "cold air intake" on it. Like I say, none of this bothers me a bit since this car was purchased primarily for my 1 and soon to be 2 driving aged kids. Coming from someone like myself who was brought up in late 70's early 80s econo-cruisers, the Versa rides/drives excellent to me in comparison.
2017 SV Special Edition bought new in December 2017. About 15k miles currently. Love the gas mileage!
Sent from my moto z3 using Tapatalk
