· MPG King!
I'm looking at 2 different rims for possible purchase... one set is 16" and weighs 21.5 pounds each. Another is 15" and 13.5 pounds each.
- Will going up in tire and wheel size affect my ride quality?
- Will it improve handling?
- Will the heavier 16" rims decrease my fuel economy?
· Administrator
Lower profile tires will improve handling, but they ride worse. A heavier wheel will also create more drag and power loss. You will notice the difference when you take off from a light and it will decrease fuel economy.
As dumb as this sounds imagine lifting 50lbs then lifting 25lbs of course its going to be harder to lift the heavier weight. Well your putting the same stress on your motor having it turn more weight. Its putting more workload on the motor. Hope that makes sense.
