1 - 10 of 10 Posts
Good point. I will have the peice i need and will use a mallet if need to lossen it. Both need to be open for maximum drain. but yeah be totally screwed if I got the bottom open and can’t get the top 😳
I got a 10 mm square head socket and it was too big. I did not get to change my gear oil today ☹. Can somebody tell me if a 8 mm is the right size?
CTA Tools 2036 Square Head Drain Plug Socket, 8mm https://www.amazon.com/dp/B00FRLBF4M/ref=cm_sw_r_cp_api_diLkBbTG18WR4
Here is everything you want to know regarding the tranny. I believe is is 8mm, but just to make sure read through the shop manual:
https://www.scribd.com/document/317797570/2013-2014-Nissan-Versa-Transmission-Info
Discussion Starter #9
I got it done and take pictures. I plan to do to DIY thread. Seems to shift better. The old gear oil did not look too dirty at 86k miles.
Its bigger than 3/8 but not by much.
You really want to remove the drain plug as its a magnet and clean the crap that has stuck to it. If its a used car, it gives you an idea how much wear has already occured.
+1 on removing the fill plug before the drain. Not that you cant use a cleaned out caulk tube to shoot oil into the drain hole and plug it fast, but its easier to use the fill hole.
Yeah, I hope to put royal purple in my tranny this weekend. My socket from amazon was an add on, so I had to buy like 25 bucks worth of toilet paper to get it.
1 - 10 of 10 Posts
