Got the headlights, but I had to adapt the H3 connection of the H.I.D.s to the H7 connection on the halos. I couldnt find an adaptor anywhere, hated to see two perfectly good bulbs go to waste, but whatevs
First you want to take the bulb out from the projector section
Disconnect it from the terminal
Hit it lightly so the end of the bulb breaks but not the whole bulb, less mess, less clean up
Drill the other side out, while drilling the lighbulb terminal will become loose, just pry those off
its hard to see, but the metal in the middle is coming apart, take the top part off, you wont need it
I had an old screwdriver that broke, this was perfect for cleaning out what was left
try to unroll the bottom part this will make it easier for the H.I.D. to fit
Cut a hole through the side. I used industrial scissors. Its hard to get open to get the wires through, but with a bit of effort and another person you can do it
The adaptor in, it will likely scratch the plastic part of the bulb, but who cares, it will be a very tight fit
The lightbulb in, it doesnt wiggle or anything
It started getting to dark, and because I live in florida, and we a plethora of mosquitos, i decided to quit and not install them, will try again on wednesday.
