How to: Change in-cabin air filter
44410 Views 20 Replies 13 Participants Last post by  Versa_dude
Changing the cabin air filter was pretty straight forward. Need phillips screwdriver and pliers. No digits were lost during this install...
Remove all screws from glove box.
Careful! Close glove box before removal, or all your stuff will fall out:ihih:
Caution! Remove light harness during box removal, or XXXXX(%^&@#(&$
Use pliers to grasp tab on old filter. I pulled down and out on filter to remove the top tab first, but you can also pull up and out to remove bottom tab first. Remove both tabs.
Slide out filter, using finger to assist top of filter.
Hmmmm, original filter? idk, i bought V used...
Insert top left corner of filter first, then slide filter in, inserting both tabs
Re-attach light bulb harness, re-install glove box screws, and verify light bulb works by turning on the headlights.
Ready for summer! 08v
1 - 20 of 21 Posts
Looks good. Nice and clean. I have to change mine again. It's been a year since the last one.
Never done mine, and I have over 80k miles. Guess I should. lol
I did it at 30k and it was pretty nasty. I couldn't imagine it at 80k. I currently have 35k on this one. I really should swap it out.
does the s have a filter? or only the sl's
I am pretty sure that almost all vehicles have one.
And yes, your Versa has one.
Oops, I thought my model didn't come with a cabin air filter and I have 50k on the original. Looks like a great weekend project. Has anyone notice and improvement in the cabin smell? I could swear that all Nissan get a weird musty smell the older they get. I noticed it riding in my buddies Sentra and now that I have my Versa, I noticed that the new car smell has been replaced with the musty smell from the other Nissans that I have been in.
I recently had the musty smell in my V, but I've had it in many cars, starting the A/C after months of non-use. After changing cabin filter, and several days of A/C, smell is gone. Also with my sentra, I sprayed Lysol aerosol through the cabin inlet, at the base of the windshield. Use a lemon scent rather than "industrial" scent for best results
thanks 08versailles, I will try and kill this smell following your recommendations.
I did my dads 99 Infiniti QX4 at 230K kms lol. Was blacker than space!
thanks for posting this... I need to do mine 86,000 Miles
cabin air filter
That's great. You set up your new cabin filter perfectly. I'll try to follow that step since I'm going to replace my cabin air filter this week.
cabin air filter change
Thanks for sharing. This is pretty helpful. I'm about to buy new cabin filter and I'll follow your instruction to set it up.
u mean remove the cabin filter.
spray Lysol on the inlet, and the base of the windshield.
then insert the new cabin filter?
^That's right, except my Sentra was a base model and didn't have a cabin filter.
I think some Versas are the same with some S models. I believe you can still put a filter in regardless. I wish I had the filter back then because a mouse made its way into the Sentra blower fan! Ewww! Yuck!
Glad thread is helpful
edit Time to change it again! Was only $16 last time
Great pics. I've changed them a few times now and gets easier every time. Should change once per year.
^That's right
what about this.
keep the key in ON position with the engine off.
Remove the cabin filter
Turn on the blower motor setting to 1 or 2.
Now spray Lysol, so it will get recirculated must faster, since the fan is running.
Works :p ?
Sounds like that will work just fine, that's probably what i'll do again, unless it's not smelly this time
Just pulled mine out of my 2008 versa that I brought used. I doubt it has ever been changed before, it was disgusting!
I see that it says that we are suppsoe to have a sticker on the inside of the glove box if we have a cabin filter...my 2012 s hb does not have this sticker...anyone know for sure if this is true? and if so can you put a fliter in if you wish? and pics would be great too.
1 - 20 of 21 Posts
