you will need:
1 nissan versa or tiida (year, drivetrain or sub-model make no difference)
1 ultra racing sway bar
the supplied hardware
1 rachet
1 17mm or 11/16" socket
1 3" extension (optional)
1 17mm or 11/16" combinatiopn end wrench
jack and jack stands (ramps dont work)
1. get the versa/tiida on jackstand and let the suspension "droop".
2. mock up bar to find holes used.
(the circles ones)
3. hold bar in place as helper ( i used my little brother) puts one nut/bolt/washer combo on each side to hold it. (bolt goes from the top down)
4. put the last nut/bolt/waser combo in both sides.
5. tighten all four nuts.
6. put versa/tiida back on all fours.
7. test drive.
8. recheck tightness (?) of nuts.
what your versa/tiida will look like with ultra racing front and rear chassis braces and rear sway bar installed.
random pic while whating for my brother to go get jack and stands
1 rachet
(the circles ones)
7. test drive.
