1 - 10 of 10 Posts
Hi everyone,
I wanted to change the front Rotors and reae drums of my Nissan versa 2008 SL. I was confused as they asked me if I have ABS or not, I went through the manual and it doesn't say anything. So how can I know if I have ABS.
Thanks
Wait until it rains then pick a big empty parking lot and slide the car there from too much brake. If you feel vibration in the brake pedal or hear any weird noise while the car is sliding you have ABS.
Or follow the brake lines from the master cylinder to see what they go to, they go to the ABS module next but you need to know what you are looking for.
You could just see if there is the ABS warning light present. From owner's manual for cars with ABS:
"When the ignition switch is placed in the ON position, the ABS warning light illuminates and then turns off. This indicates the ABS is operational."
Good point but on some cars the ABS light is the same light as the parking brake and low fluid. It then just says 'brake'.
And, if the ABS is not working at all, the light of course then means nothing.
When you turn on your car, the ABS light will come on briefly. It's usually some sort of circle with "ABS" inside it.
I was under the impression that for 2008, ABS comes standard on all Versa.
When you hard brake using ABS, you can hear a pumping sound as the ABS pumps the brakes. It's disconcerting if you never had a car with ABS before.
Paul
AMC49 why would you give YUSUF such nonsense info on ABS( WAIT TILL IT RAINS AND SLIDE THE CAR ??? REALLY!!!) how about YUSUF look at your strut ( I can't tell in the picture) but 1: your brake line hose is connected (or attached to the strut to keep it out of the way) 2: if you have a black wire (also attached to the strut and goes into the wheel hub (black plastic and held on with a 10 mm bolt) you have ABS, if only a hose and no wire no ABS I hope that helps
1 - 10 of 10 Posts
