What's going on Versa peeps!
My girlfriend owns a Versa as well but it's a sedan model instead of the hatch. Oh and it has about 120,000 miles on it. Pretty insane considering she owned it for just 5 years! :eek6: With this many miles saddled on any car, things are bound to go bad; sure enough, her alternator died the other day. Naturally I was called into duty to fix her ride :thumb2:
So here is the procedure for replacing the alternator on a '07 Versa. It probably applies to other model years and the hatchback model too :smilejap:
Where is the alternator located relative to the engine?
1) Disconnect the battery cable from the negative terminal.
2) Remove drive belt.
3) Disconnect alternator connector.
4) Remove “B” terminal nut. Be sure to tighten “B” terminal nut carefully.
5) Remove alternator bolts.
*diagrams courtesy of nissanpartszone
6) Remove alternator assembly from the vehicle.
To install:
1) Installation is in the reverse order of removal.
Good luck guys! :woot:
To install:
