Ok to start off you are going to need a flat head screwdriver and a phillips head screwdriver.
you door should look something like this. With out the L.E.D blue. (ALSO YOU CAN DO THIS ON ANY DOOR THAT YOU WISH TO TAKE OFF)
Now you take the FLAT HEAD SCREWDRIVER and place under the silver part on top to pop it off its really easy to do like this
now, part is out of your way now you take the FLAT HEAD SCREWDRIVER once more and put in the center of the door and pop up the switch like so
now that you have done that un-plug the the switch from the wires like so
the are too screws this is where the PHILLIPS HEAD SCREWDRIVER comes into play. you want to take them out if they drop its ok you still have to get the door off so its easy to get them back lol i did it.
it looks like this
now take them out and you see this
now place you hand on the bottom left side and pull up and it should just pop
and this is what you will have
now that you have done that you can now do whatever you need to do like doing L.E.Ds or even change the stock speaker like so
now that every thing is done and you did what you need to do follow these steps backwords to get the door back on and you have now learned how to take your door off and remove your speaker
im glad this post is a help to most of you thanks
Adam Huaman
it looks like this
Adam Huaman
