1 - 20 of 110 Posts
Hello everybody.
I am starting this thread since a lot of owners of hr16de cars (micra/march, versa sedan, tiida sedan and versa note) in south america, mexico and canada are having engine fault.
The fault is a rod knock since car is brand new, is not a sever red knock, only audible with warm engine and light throttle.
I will le you the steps to perform the rod knock test and videos showing the problem.
STEPS TO TEST THE KNOCK:
1) Car in Neutral With Park Brake On.
2) Start Car, idle to normal operating temperature ( 20 minutes).
3) Place smart phone/camera/audio recorder on ground under front bumper near oil pan, recording
4) Slowly press accelerator pedal to 2500 rpm and hold, then depress slightly until rpm drop to 1900, and then press again until 2500rpm.
5) Repeat step 4 a few 10-20 times, rpm increase and decrease must be very slow, with very light load on throttle.
6) share video/audio.
Official nissan explanation to this problem (in spanish, paper came out nissan factory in aguas calientes, mexico), it seays is a rod knock and repair procedure (replace pistons, rings, barings, rods, etc).
On canada forum, some people had their engines replaced and new engines are knocking again.
Also some cars knock since brand new (like mine, and other memebers) and another we think yes, but owners only noticed the knock after some mileage (because tends to get a little worse) and others because they saw post on forum, made the knock test, and found their engines were also knocking.
Some videos:
nissan march less than 1.000 km:
https://www.youtube.com/watch?v=_9cGXMIK7Yg
https://www.youtube.com/watch?v=CT27UoARszo
nissan micra less than 700km:
https://www.youtube.com/watch?v=cqaB2e6O2Lk
nissan versa note, 190 km:
https://www.youtube.com/watch?v=wIJDpwQFliE
nissan micra, 40k km (start video at 2.35):
https://www.youtube.com/watch?v=aK_gWgIciYE
nissan micra, 36k km (start video at 1.00)
https://www.youtube.com/watch?v=5CrCV3ZvQAc
same micra with new engine, 1500km on new engine, nissan said new engine has to be replaced, as you can hear, it knocks a lot less than the old one, because knock becomes worse with mileage, start video at 5.40
https://www.youtube.com/watch?v=W5mZEzG5Mfc
micra 1200km:
https://www.youtube.com/watch?v=avE8BEpBLVg
i know a guy in stataes that has his versa engine replaced at 35k due to the knock, and new engine started knocking again at 15k miles, the guy sold the car.
So plase perform the test, and share your experience.
must be them new HR's because mine is rock solid! 2009 HR16DE no maintenance other than oil changes every 7500-10,000 miles. Of course now that I said that it will probably blow up.
But good post about the knock.
  • Like
Reactions: JoshG
Discussion Starter · #4 · (Edited)
is your engine made in mexico?? is the hr16de equipped with 8 or 4 injectors???
at present both versions of hr16de have the same knock, very simple explanation, the bottom end is the same on both.
The oldest models i am aware they have this problem are 2012 made in mexico.
15k miles on mine and time for an appointment for a tap that I'm hearing.
have that noise checked at the dealer, you can also perform the knock test by yourself, is a very easy task
I think I picked up this noise at start up while accelerating out of the driveway a few weeks ago. I will have to preform the test this weekend.
Thanks VV
Bumping this old post because it's very important.
I tested my 15 note at 5000 miles and it for sure had the knock. Very clearly could be heard as per the instructions.
According to the micraforums thread, a very large number of new versas will have this issue which can lead to a lot of headaches, poor power and gas mileage, and decreased engine life.
The diagnosis takes a while since the engine needs to be removed and Nissan is hassling people by trying to say the noise is normal. There's talk of class action lawsuits, since Nissan really doesn't want to completely replace every versa and micra engine made in the past few years.
For me, I wanted out before the resale value drops like a rock due to most versas having this problem. That and I didn't want to have the car stuck in pieces for monthss Nissan tries to get parts in, which they are "mysteriously" out stock on suddenly world wide. Aka, they aren't announcing a worldwide recall, but are using up the entire supply of parts in secret in an attempt to keep this out of the public eye. So I took the $2000 loss and traded it in towards a 16 fiesta st.
Word to the wise, do the test. If it sounds like it's knocking, get the ball rolling now because you don't want to wait until you're out of warranty.
Discussion Starter · #8 · (Edited)
well, small update.
my micra is at the dealer, engine is fully disassembled and there is clear damage in crank and rod bearing at cylinder 2.
problem is as the tip in spanish says bad assembly between rod cap and rod, so you end up with a slight rod knock.
here i know of 2 engines that throw a rod, one was 30k km, the other around 60.
the owner of the second one reported that he sometimes felt an strange noise but since the car was runing strong did not complain.
car was 2 or 3 month out of warranty.
also in mexico there is another guy with a 2012 versa that throw the rod at 49900km, was 5 month out of warranty.
he had to wait almost 3 month for new short block(and he lives in mexico, where engine is built), during that time i sent him the technical tip i posted here, he showed the information to the dealer and after that he mysteriously received a 30% disscount in new short block and labour.
in my case i had to wait more than 3 month for new internals to arrive so i can have the engine repaired.
all has to be replaced, pistons, rod, bearings, crank, etc.
replacing the engine IS NOT AN OPTION because new engines are still being produced faulty, you can see at the micra forum of canada that many people had the engine replaced and knock is still there.
in my case i will sell the car ASAP no matter if i loose some money and get a proper 100% japanese built car, a zc32s swift sport.
i encourage all the members of this forum to perform the knock test on their engines, you will be amazed with the results.
of course this is my first and last nissan.
legatinho
according to my dealer (they are very aware of the piston slap issue in tiida) the problem was fixed in that engine using a new design of rod and piston, that design is used in the hr16.
i dont know if that is true or not.
I'm not sure if my car is making it, I don't have that good of a mecanic's ear to notice, I have a 2014 V-Note SV that was bought in October 2013 and is now just over 55,000 miles.
Mine seems fine, but I only got 47,000 on it. 2014 Versa Note, bought in April of '14
Is there anything I can do to prevent this, if I don't have the problem yet?
I'm well out of warranty. I had warranty work for leaking front timing cover.
Now I am concerned. Will drive it easier for sure.
Discussion Starter · #11 · (Edited)
well you can easily test if your engine has the knock problem or not.
1- warm engine (15 minutes of driving or 20 at idle is ok).
2- place a camera under the frot bumper, near oil pan area.
3- VERY VERY slowly start pressing gas pedal on neutral and let rpm rise until 2500.
4- when rpm are at 2500 lift off your foot from gas pedal a little bit so rpm wont keep rising, keep them at 2500 for 2 or 3 seconds and now let them go down VERY slowly until 1900 (so you dont have to lift off you foot completely, only a little bit so they can start decrease slowly).
repeat step 3 and 4 several times.
5- upload video and share it here on forum.
here you have an excelent example showing a good place to place the camera.
engine is from a micra, 100% the same of the note.
also on this video you can clearly listen the knock after minute 1.10, see how light load on gas at around 2000rpm makes a noise that goes away when rpm drops
there is nothing that can be done to prevent this, engines are rolling out of the factory with improper clearence between rod bearing and crankshat, thats what is causing the knocking noise (rod knock).
because parts (crank, bearings) are saddly very bad quality, some engines knock louder than others, but there are a lot of knocking noises engines out there and 95% of the owners are not aware of this because for 99% of people is not an easy noise to detect.
a lot of people on the micra forum thought their car was knock free and after performing the steps above noticed the knock was there, some with 40k km.
i know 3 engines that throw the rod, allways cylinder number 2, 2 versas and 1 micra.
Any bearing will go if tolerances are not right, what do you mean bad?
So I need to do a UOA on my oil at next change. IF the bearings are taking a beating, then there should be elevated levels of metals!
I am running Mobil 1 EP 5w-20 and going to increase octane of gas. I do not detect knocking, a UOA of the oil should give me some indicators, as bearing wear would occur before the slap.
Discussion Starter · #13 · (Edited)
yup on the micra forum there is a guy who took his car to the dealer for the knock with 700km on the odo, oil sample was taken and there was metal in the oil.
i saw my engine's stock internals when the engine was disasembled and on cylinder 2 main bearing was damage, same on the crankshaft, clear sign of rod knock, also bad clearence was confirmed by the tech, car has less than 10k km.
felt the knock since day 1.
i would recomend you perform the knock test with the camera under oil pan and share video,
My 2016 has 250 miles on it and i can hear the rod knock. Drives me nuts! Guess i will be calling the dealer.
Discussion Starter · #15 ·
really sad to hear that.
it seems that the problem is not solved already, what a disgrace/
let us know what they tell you.
do you have any video to share???
which series is your engine?? you can check the engine number on the engine itself, it starts HR16NNNNN(Numbers) and ends with one letter.
share the HR16NN......Letter,
I will get vid footage for everyone. I will also Check for the engine number. The bearing rattle is getting worse . Now have 400 miles. Sad how bad it is. The dealer will fix it but i am thinking i should wait so the proper replacement engines will be available. No sense in having the engine replaced if the replacement will not be any better. Thoughts?
Discussion Starter · #17 ·
it appears that some hr16*xxxxxxx ending with L have the problem fixed (or at least improved).
please share video of actual engine and series and last letter of it (for example HR16*76xxxxxH, you dont have to share full number, only first 2 numbers and ending letter.).
what did the dealer say about the knock??
I had to drop the Versa off sooner than expected. wasnt able to get a video of the knock. But the knock was louder than some of the videos i have watched. The dealer went through a series of tests and the engine had low oil pressure and severe knock.
Long Block on the way. I will keep everyone posted. Car only had about 490 Miles.
hopefully new long block will be knock free.
when you have a rod knock oil presure is afected.
The tech will take pics for me of the removal and install and i will get the engine serial number for everyone.
1 - 20 of 110 Posts
