Please give us ALOT more details. Year of car, type of transmission, what does "funny" mean. Try and describe what your doing with the car, when it appends.
Hello everyone,
For starters: the car I'm driving has less than 30k miles and is a 2014 Nissan Versa 1.6 SV.
For the past week or so, I've had the yellow, non-blinking Check Engine Light on. The car seems to be driving perfectly fine, with nothing out of the ordinary.
Finally took it in for...
I searched the forum and found instructions to remove airbag & steering wheel to replace clockspring (spiral cable). The airbag releases partially when the springs are engaged with a screwdriver, but it will not release fully from the steering wheel. Has anyone encountered this problem, and if...
Hi everyone,
I just wanted to get some opinions, since I'm trying to troubleshoot what might be wrong with my Versa.
2009 HB, 1.8L SL automatic transmission. About 137k miles.
As per the title, when engine's cold, there is a screeching noise coming from the engine (checked drive belt but...
I am having a problem with my 2008 Versa HB. I replaced the clutch, but i am having a hard time bleeding the clutch. I have used the FSM procedure with no luck. This is the car I have to use for work! So I need help quick...
Thanks in advance
