Check out this post:
http://www.nissanversaforums.com/how-tos/3628-how-adjusting-valve-lash-clearance-07-versa.html
To tell the truth, I wasn't aware that this engine had shim-under-bucket solid type lifters.
This style requires removal of the camshaft if adjustment is required. To only check is relatively simple.
I swapped an exhaust valve shim on my Honda 919 during my 16k routine. Methodical work is the key here. If you have a service manual, it makes it much easier (and safer).
