Hi,
My 2007 versa will start without a key and won't turn to the "lock" position.
The ignition switch seems to "think" the key is in the ignition switch all the time as the warning chime dings continuously after I shut the car off and remove the key eventually leading to a dead battery. I took it to a mechanic and was told the "inter lock shifter was broken and would be about $600 to fix it. Any suggestions?
