I called my local dealer. And I asked them what it would cost to make the switch. I have a 2020 Versa S with the old school headlights. To make the switch I would upgrade the wiring harness under the hood. As well as buying the LED headlights. And labor. The cost ? At least $4,000. Most likely more. Wow. I guess I won't be doing that anytime soon. LOL
Instead of replacing the entire headlight housing unit you wouldn't consider just trying to switch to LED "bulbs"? I haven't done this in my Versa yet but I did on my motorcycle (Honda ST1300). Twas a very noticeable upgrade and the bulbs put out effective lighting.
Sent from my SM-N960U1 using Tapatalk
I replaced the headlamps in my 17 Versa Note with LED bulbs. Huge improvement. You must be careful to get the style that the LEDs mimic the incandescent beam pattern!
Do yourself a favor, now lets stay focused here...IT'S A VERSA! I know you love the car, we all do but unless your an automotive electrical hobbyist...leave well enough alone...that's what it was designed with, leave it alone! If you have money burning a hole in your pocket then upgrade the Rims, upgrade the interior, lay down a million coats of Covid19 proof clearcoat...but I don't mess with Lighting, it can get more complicated than you think.
Upgrading is a great idea but $ 4K is insane (Thats how dealers are). anyways there are some stuffs you gadda understand when you plan to upgrade to LED.
You can just change the Bulb to LED but the Housing reflector won't work same as for Halogen / Whatever the bulb is there now. If you want exact light quality you gadda retrofit you Headlight set itself, Like adding Projector lens (This will give you a nice & controlled beam) if you just change the LED bulb with existing Reflector the result will be so much glare (Beams will be spreaded all over the place, it will cause irritation to on coming traffic, in that case you have the lower the focus to very low to ground and again it won't be enough you to see the road bit further.)
If you are ready to do some work. Just buy the Projector lens and retrofit it & add the LED thn you'll have a controlled & nice LED BEAM.
I have a TIIDA 2012. I changed all the bulbs to LED except Blinker (Due to technical reason. it will blink faster as I didn't add a driver for tht)
  • Headlight, I just added the LED without Projector, As I'm okay with the very low beam, Coz I live in Concrete Forest ^_^
  • Parking light, reverse light, brake light, Cabin light & Also I added a 2 in 1 DRL which comes with blinker. All are LED.
In my view LED gives a rich & Nice look to the Car.
My advice to anyone looking to upgrade their lighting is to keep it as simple as possible.
I learned this when I did a retrofit to HID on both a '01 Ford Ranger and '06 Mazda Tribute. Had to point the Tribute's headlights as far down as possible but they were still bothering oncoming traffic, so I opened up the headlight assemblies and added projectors. Much better. Problem is the vibration caused the HID bulbs to fail too often, good thing the place I bought them from gave me a lifetime warranty. My Ranger's headlights have dulled and I'm thinking of replacing them with aftermarket headlight assemblies that already have the projector molded in.
Finally traded in the Mazda for my 2020 Versa SV, and have been missing the extra visibility at night. I was thinking of doing something similar to my previous vehicles and that's what brought me to this forum. I was wondering if it would be possible to just upgrade to the SR headlights, but no way I'm shelling out $4K. The plan now is to install aftermarket assemblies with the projector, and plug-and-play LED bulbs that won't require messing with the wiring harness.
Omg. It's a pure robbery. I can't even believe how they could demand at least 4000$ for that. Sometimes I think about doing everything on my own. Nowadays you can't rely on anyone. Finding a decent, friendly, and honest bloke for that work seems to be more like a gold hunt. I was thinking about an enlightening interior project for my Versa, but now I'm more convinced that I would better purchase some smart strip lights Best RGB Smart Strip Lights | Smart LED Strip | LED Strip Lights and have them installed using my free time and minimal resources.
