my interior driver side door handle stopped working (will not open the door) it feels as though it is not "catching" and is loose. the handle remains in place and the lock mechanism works.
has anyone had this happen or know of a way to remove the interior assembly & repair?
any information would be hugely helpful!
One of the cables may have broken or popped out of one of the retainers, or the lock actuator broke. Pry out the window switch block with a plastic trim stick if possible to avoid marring the vinyl or the plastic. Unplug it. Remove the two screws holding the door card to the interior door structure. From here disengage the top seal retainer strip from the door structure by rolling and lifting the door card until you feel it come off the door. Then just disengage the trim clips by using sharp/abrubt pulling force near the edges of the door card (when you use sharp pulls you're less likely to break any clips or the plastic on the door card that holds them).
