Sometimes my Versa will not start when I go some place and I try to start the car. If i wait 20 minutes , the car will start. This is an intermittent problem and doesn 't occur every day. when it happens i can smell gas and the car just turns over with out starting. thanks for any sugestions
If you smell gas, you may have a leak in a fuel line that is dropping fuel pressure. Without adequate fuel pressure, there will be a delay until the engine starts.
Have you pulled codes from the OBD2 diagnostic system?
My tiida stoped while am motion and when i try to start the car it will show key light steady ,
I have changed immoblizer its still the same , i try to scan the car it did not communicate .
Could it be the Brain Box.
