Or do I need to buy some special Nissan coolant from the dealer?
I'm going to do a coolant change and a local radiator shop suggested I look into the Versa needing special coolant from Nissan.
i think Prestone is fine. years ago the concern was compatibility with aluminum. no "nissan only" i believe...or just top up with water
Prestone extended Life Antifreeze
Good Morning,
I am the tech manager at Prestone Coolants. Prestone extended life coolant exceeds all ASTM standards for coolant set forth by Nissan. You can drain and flush your cooling system and use Prestone extended life coolant in your Versa. If you need instructions, I am happy to send them, just send your year and engine size to [email protected].:thumb2:
