1 - 8 of 8 Posts
I just bought a 2008 Versa 1.8 4 spd auto. The car is in great condition with 145000 km on it.
really the only issue I have is a very harsh shift from 1st to 2nd and to a lesser extent 2nd to 3rd
this occurs at normal takeoff speeds --If you give it the onions it shifts as smooth as glass.
Had it into transmission shop and they claimed there was nothing they could find wrong.
can anybody shed some light on this?
How is the trans fluid?
Full? Pink? Brownish? Smell burnt?
When was the last time it was changed?
looks perfect on the trans fluid--at the proper level and nice clear reddish pink--My brother suggested a Throttle position sensor might be screwed up--or trans output speed sensor
If there are no codes, the cheapest option is make sure the throttle body is clean and then do a re learn. Plenty of info on how to do both around.
Discussion Starter #6
no dice--it does have an o2 sensor code lit up bank 1 sensor 1--will change that--any advice on where to purchase that sensor where I won't get raped?
Any auto parts store will have them. Try to get Denso and stay away from Bosch.
On a side note, do you know of any auto recyclers that ship to the U.S.?
Looking to get heated door mirrors, and I will have to import them, as they were not available here.
1 - 8 of 8 Posts
