1 - 10 of 10 Posts
My daughter has her 2007 Versa home for a while now and says that it does not start like it used to, when she got it in 2019 from a used car dealer down in FL. I tried it and the difference seems to be that while at first when you turned the key, the engine would start almost immediately; now it makes one or two cranking sounds then starts.
I took it to an Autozone thinking possibly a weak battery, but they said the battery was good.
I can't really afford to simply throw money at it until i find out a solution that might never come with what i am capable of, and though i suspect it can't be a bad idea to replace the plugs (i really hope they are easily accessible on this) and start adding Berryman B-12 or Techron, i was hoping that one of you folks that knows what you are doing could give me a prioritized hit list of what to do.
Thank you for your help!!!
If it is still rolling over quickly but taking a couple extra seconds to start I would say its not the battery. It could be many possible issues. What comes to mind is the coil, they are fired based on crankshaft position (+/- commanded timing) so a weak or faulty crank sensor would cause a delayed start. Do you have any codes present?
Save your money on the chemicals. Plugs are not "easy" to get to, and I wouldn't look at them unless it's misfiring or over 100k miles. You really need data to live forward without wasting money. It would be worth it to seek out a diagnostic tech in your area and pay the fee. This is always the best choice when people don't have the tools or know how to tackle drivability complaints. It's early always cheaper than guessing.
Discussion Starter · #4 ·
Thank-you!!!
I will give a try with my cheap-o scanner, didn't think of checking for any pending codes without the MIL on, but now you folks mention it, i recall they can be present-
As my opportunities to check that car are sporadic, may i say now MERRY CHRISTMAS!!!
08 versa hb
That's not much information to work with. If you are sure the battery is good and the motor is turning over quickly enough, that is the first thing to make sure of. How many miles are on the car? As others have stated, a scan with a diagnostic tool would be a good idea. If the mileage is high and you do not know the cars history, the plugs would be a good place to start. I have done that job and it is a fair amount of work, but not to complicated or terribly expensive( maybe 50-75$, depending on what parts you use). I replaced the plugs in my 08 at 70k miles. And there are videos online to help you out. Other than that it could be any number of things. Coil packs could be an issue if nothing shows up on a scan. Maybe that would be indicated on a scan, I don't know.
I suspect what i fear most at this point are that the injectors are getting clogged, but i know i best start somewhere and you folks have pointed me in the right direction. I'llpost back with anything i find; Thank you!
Can't say I have ever seen plugs cause hard starting that didn't also misfire while running. With a scantool that reads live data, you can tell a lot. Just spend the $10 and get a Bluetooth OBD2 dongle and an app. They are worlds better than anything else for much more money. I made a video in the diy how to section of the spark plug process a while back.
Discussion Starter · #8 ·
Thank you everyone!
Well, no codes whatsoever. Kinda means i need to be considering the injectors, doesn't it?...
Discussion Starter · #10 ·
Thanks! I really am leaning towards the injectors needing cleaning, but i liked the test with starter fluid. Of course, the way he sprayed it, i was expecting an explosion... Got some good ideas for the future also, just wish he wouldn't yell so much! Watch a lot of his videos-
1 - 10 of 10 Posts
