I have a 2008 Versa S. I like the car a lot! However- I have had an issue with the driver side rear turn signal. Sometimes when I put the turn signal on (left turn) the arrow goes like crazy! Clear indicator of possible bulb failure. I got into the bulb area after watching a you tube video. The 7507LF is intact! And after turning it a bit, it will work. Then after a spell, it goes back to crazy again! Am I the only one who is adjusting this bulb daily?
ALSO: My 6 disc changer has eaten 2 discs and will not eject them no matter what I try . The radio works fine, but i know Ineed to replace. but If ican get it to work I'd rather save the money. Any and all help with either issue would be appreciated!
As for the turn signal issue, you might want to pick up a can of electronics cleaner from most any auto parts store. It is made especially to clean electronic circuit boards, bulb sockets, and plugs. Cheap fix!!!
