My son has a 2014 Nissan Versa Note that has a check engine light. The diagnostic code is P0196 "Engine Oil Temperature (EOT) Sensor low" . Can anyone help me locate this sensor on the engine so I can test it? Thanks.
I pulled out my repair manual and it says that the oil pressure sending unit is located on the front side of the engine, near the starter.
Thanks. I subsequently got the 2014 Versa repair manual. On page EM-92 it shows the location of the engine oil temperature sensor in an exploded view of the cylinder block. It looks like it is on the side of the engine that you can access by opening the hood. I say this because it is on the same side as the oil dipstick.
