After the first time removing my front bumper, I've never been able to get it locked in place properly in the front. Any suggestions?
What Josh said, how are the sides? You may have some side clips broken, I've had that happen to me before. I would personally remove the grill and front bumper, check the issues, and then re-mount to see how the fitment goes. Mount and check, mount and check..also once your bumper is removed, you can then see if any clips or anything is broken..good luckAfter the first time removing my front bumper, I've never been able to get it locked in place properly in the front. Any suggestions?
My bottom headlight clips are just not up to the task. I'm almost certain the missing support at the very front of the bumper is allowing it to sag down.Like Josh said before, there is a place where the bumper slides into under the headlights. That should get rid of the clearance issue from your first post. I hope you get it all square away!
