I noticed this a couple weeks ago on my 2007 Versa after I had my oil changed at Valvoline Instant Oil Change. It's quite loud. The car seems to be running fine. Fuel mileage seems the same.
If I floor it at 2k rpm or higher I get this noise.
What is it?
If they checked your air filter as VIOC tends to do, they likely didn't put the air cleaner housing back together properly or knocked a connection loose.
can you reproduce the noise in park, with someone revving the car up a bit?
Also, double check your oil level. "trust, but verify"
