Anybody have problems with the air massflow sensor my check engine light came on recently and they pulled that the sensor not good not the first time this happens thou.
Remove it, clean it with some electronics cleaner spray, wipe all connectors and sensors with the spray using a qtip, replace maf sensor, remove the negative battery cable or main fuse and leave some sort of light on (like leaving your door open) for a couple minutes, and then restart the car. See if the CEL went away or the problem continues.
Discussion Starter #4
Hasnt been replaced before I've only had the car 2years and the last time this happened i had cleaned it. It worked until now this was last year when i cleaned it.
