Hey guys,
I'm thinking about an engine head swap, I found that in both engines the piston diameter is the same. So, i guess the displacement differences resides on a bigger engine head. Do you guys know anything about this? Is it possible to get an mr20 engine head on an mr18 engine block? Compression rate would be affected, but if the engine blocks are the same, i don't think it would be a problem.
What do you think/know about this?
