Hey y’all I’m new here from south Texas
I own a Nissan I Versa I loved till I started having issues.hopefully I can get some advice or pointers from someone who’s had same issues as I and found the fix
Thanks all
The issues are?
This is what the original poster listed as the problem in another section:
I’ve spent a fortune trying to fix this car.
I bought it with 102k and now has 133k
The car ran beautifully,the first 30k
my stepson accidentally washed the key fob and that’s when all the problems started.
We never used the key to start car until after the incident.
So far I’ve replaced all the sensors twice,the catalytic converter ,1 ignition coil,fuel pump,fuse box
The first mechanic swapped all the sensors,cat and fuse box.then it still turned off.
He advised me to take it to the stealership.
They had it twice and still can’t figure out why it turns off.the dealership replaced the sensors again and replaced the ecm and reprogrammed it.they say it’s still running lean and turning off but can’t figure out why it’s doing it.
I just don’t know what to do anymore.i hate to dump more money in it.bit I will if I can find the cure and get at least 35k more k to offset the expenses.hate to get in debt for another car when this car was running well
Has anyone had this issue and found the problem.
Thanks appreciate all feedback
