the front windows shouldn't have a "lock" they are sposed to go all the way down and as far as I know all 4 should go all the way down at least mine do (09 sedan s)
^^^ Thats a good point. OP...If thats the case, you can go to a pick-n-pull, find a newer Infiniti G20, and get the brackets off the doors. Thats what I did when I decided to replace my original speakers...all 4 speakers for $20(with brackets). :thumbsup:
I think that the dealer when they remove front window for remove the tint window... the Mirror Cable blocked the window, I will see that this weekend (If I'll have time)
I have another trouble to find.. my DRL light on, when I light on night light on low beam (the lights close) but If I put Hi-Beam the light on! (right side of car) I think at the Short because I changed the bulb!
Hello,
I bought a 2013 Versa SV earlier this year through Ebay. When I received the Versa the transmission fluid hose had been damaged in shipping and some of the fluid was lost. Called the previous owner and he told me that the transmission had been replaced and that the Versa did not have a...
My trunk light went out on my 2007 hatchback a few years ago and I chalked it up to a burned out bulb. I finally got around to taking a look at it today, and when I pried off the light housing, it just popped off--nothing was connected to it. (In other words, the bulb may have not even been...
Hi everyone,
I just wanted to get some opinions, since I'm trying to troubleshoot what might be wrong with my Versa.
2009 HB, 1.8L SL automatic transmission. About 137k miles.
As per the title, when engine's cold, there is a screeching noise coming from the engine (checked drive belt but...
Hello everyone,
For starters: the car I'm driving has less than 30k miles and is a 2014 Nissan Versa 1.6 SV.
For the past week or so, I've had the yellow, non-blinking Check Engine Light on. The car seems to be driving perfectly fine, with nothing out of the ordinary.
Finally took it in for...
